Japan 2011 - Fukushima
Idite na 1, 2, 3, 4  Sljedeća
-> Nuklearna energija
Pridružen/a: 09. 07. 2009.
Postovi: 3174
PostPostano: 15.3.2011. uto. 21:49    Naslov: Japan 2011 - Fukushima Citirajte i odgovorite
nisam vidio da ima vec neka tema posvecena trenutnim dogadjajima pa mozda nebi bilo lose staviti par linkova
http://en.wikipedia.org/wiki/Fukushima_I_nuclear_accident
ako vjetar dopuše situaciju k nama pratimo ovdje
http://www.radioaktivnost.si/ewsmambo/EWS/POZDRAV/MZO_gmaps.html
http://www.dzns.hr/aktivnosti/pripravnost/pravodobno_upozoravanje
slobodno dodajte interesantne podatke ili linkove
btw KI nema u ljekarnama ali nam itako nece pomoci jer je poluraspad joda 8 dana, a cezija 30 godina Smile))
nadam se da vam gajgeri veselo rade!
PostPostano: 15.3.2011. uto. 22:02    Naslov: Citirajte i odgovorite
Ako krene nizbrdo, ovo je scenarij...
PostPostano: 15.3.2011. uto. 22:04    Naslov: Citirajte i odgovorite
Trenutak eksplozije reaktora...
PostPostano: 15.3.2011. uto. 22:07    Naslov: Citirajte i odgovorite
PostPostano: 15.3.2011. uto. 23:03    Naslov: Citirajte i odgovorite
o ovome se priča u ovoj temi :
http://e-vozila.com/forum/viewtopic.php?t=1130&postdays=0&postorder=asc&start=105
Postovi: 5537
PostPostano: 16.3.2011. sri. 00:10    Naslov: Citirajte i odgovorite
Ona prva mapa nema veze sa nicim...Australci Rolling Eyes
http://www.theweatherspace.com/news/TWS-3_14_2011_accuweather.html
(TheWeatherSpace.com) -- TheWeatherSpace.com Senior Meteorologist Kevin Martin is upset at Accuweather using what credibility they have left for scare tactics, developing a more realistic fallout map.
Accuweather released a statement that radiation from Japan's Fukushima Nuclear Power Plant would reach the United States and cause a serious concern.
"We are humans and thrive on doom, however we need to calm down and think things over before scaring the living daylights out of people like Accuweather is doing," Martin said. "The only concern is the area around the facility, which is why people are being evacuating".
Accuweather Meteorologist Jim Andrews warns about particles on the ground in a release on Monday. "Although such a cloud would pose virtually no threat while in the upper atmosphere, the fallout at the ground of radioactive particles from it should be a concern for any monitoring authority", he stated.
Martin has things to say about that.
"The activity will be dispersed over a wide area, but that concentration would be so low that it would go virtually undetectable due to wind shear in the atmosphere, tearing the particles apart", he said. "This is like throwing a bag of feathers in the air and thinking all of them will float a mile with the wind. Particles are heavy, so I would think most of them would stay around the facility; and if they come east, would only go between Japan and Hawaii before sinking back down".
There are still conflicting reports on what will happen, however Martin states that he does not want to just instill the fear of any incident like Accuweather's Jim Andrews has done and for people to not panic because of Accuweather's fear.
Martin has developed a model and overlayed it with 'Google Earth' to show the behavior and intensity of radiation should it leak out from now till Wednesday. (see image)
Martin tells me over e-mail that a strong jet will be coming into the Japan area at 18,000 and 25,000 feet that will carry anything airborne at that level to the east by northeast.
Postovi: 12731
PostPostano: 19.3.2011. sub. 11:45    Naslov: Citirajte i odgovorite
Priopćenje o nuklearnoj katastrofi u Japanu
Udruga "Eko Kvarner" smatra da treba ukazati na nepotpuno i manipulativno informiranje hrvatske javnosti o nuklearnoj katastrofi u Japanu. Naime, kao komentatori tog tragičnog događaja u hrvatskim se medijima skoro isključivo pojavljuju domaći eksperti iz domene korištenja nuklearne energije koji (vjerojatno zbog vlastitog subjektiviteta) ne iznose izuzetno važne informacije koje se mogu naći u skoro svim stranim medijima. Podsjetimo, u prvim vijestima Hrvatskog radija u kojima je ukazano na izgledne probleme sa nuklearkama nakon potresa i tsunamija u Japanu, domaći su nuklearni stručnjaci rezolutno odbacivali mogućnost bilo kakvih problema s japanskim nuklearkama zbog njihove tehničke savršenosti i visoke obučenosti osoblja (te su informativne emisije i sada dostupne na internet stranicama Hrvatskog radija). Kada ukazujemo na prikrivanje važnih informacija, prvenstveno mislimo na dva izuzetno važna podatka.
Kao prvo, iako nam se nuklearna industrija već desetljećima prikazuje u idealiziranom obliku vlastite savršenosti, sada se u Hrvatskoj ne objavljuju instinite informacije o vlasniku nesretnog postrojenja. Naime, "Tokyo Electric Power Company", što je puni naziv koncerna TEPCO, sa svojih 50 tisuća suradnika i prometom od oko 40 milijarde eura, spada među najveće energetske koncerne na svijetu. Ali taj koncern je i prije katastrofe u Fukušimi bio "po zlu" dobro poznat Japancima i to po sklonosti da zataškava incidente u svojim atomskim elektranama i utječe na političare, a počesto ih i potkupljuje. Japanski i svjetski mediji su godinama javljali o skandalima u kojima je energetski div potkupio političare ili zataškao neki od brojnih incidenata u njegovim reaktorima. Vlastima na kraju nije preostalo ništa drugo nego da još 29. kolovoza 2002. zabrani rad svim reaktorima tog koncerna u Japanu i naloži provjeru njihovog stanja. Zbog toga 30. rujna 2002. godine s funkcije je morao odstupiti predsjednik uprave TEPCO-a Hiroshi Araki, predsjednik Nobuya Minami, podpredsjednik Toshiaki Enomoto i savjetnici Shō Nasu i Gaishi Hiraiwa. Govorilo se o preko 200 zataškanih incidenata između 1977. i 2002. Nažalost, jedva da je prošla godina dana da su političari popustili i dopustili rad baš svim reaktorima - usprkos prosvjedima građana. Za krivotvorenje podataka TEPCO je također optužen 2006. i 2007. godine. Upozorenja su se ponavljala godinama od strane stručnjaka raznih profila, ali propaganda nuklearne industrije u sprezi s korumpiranom vlasti uvijek je bila jača. Jedno od zadnjih ozbiljnijih upozorenja je 2007. godine dao poznati japanski seizmolog Ishibashi Katsuhiko (profesor urbane sigurnosti na Sveučilištu u Kobeu). Profesor je posebno istaknuo veliku osjetljivost japanskih nuklearnih elektrana na snažnije potrese. Incidenti su se i dalje dešavali i već 2007. je u potresu bio oštećen jedan reaktor koncerna TEPCO i iz nuklearke je u atmosferu izašla radioaktivna para. Koncern je i taj incident isprva pokušao prešutjeti, mada se ubrzo ustanovilo kako je već tada Japan bio na pragu katastrofe kao i ovih dana. Inače gledatelji BBC-a su proteklih dana mogli vidjeti da lokalno stanovništvo u Japanu na upite novinara vjeruju li u javnosti dane informacije o pravim razmjerima katastrofe, rezolutno daje niječne odgovore, vjerojatno poučeni dosadašnjim iskustvom s nuklearcima.
Kao drugu skandaloznu manipulaciju s javnosti treba navesti umanjivanje mogućeg utjecaja na zdravlje građana do sada priznate količine u okoliš ispuštene radijacije u Japanu. Iako domaći nuklearci stalno govore da je u okoliš ispuštena radijacija zanemariva, japanski ministar obrane Kitazava je objavio kako je izmjereno 4,13 miliseverta na sat. Danas se u svijetu i ta količina smatra opasnom jer npr. u Njemačkoj se normalnim smatra izlaganje radijaciji od 1 do 2 miliseverta - na godinu! Ključno je ukazati i na sve brojnija znanstvena istraživanja koja sve više ukazuju na pogubnost dugoročnog i kumulativnog izlaganja čak i niskim dozana radijjacije, pogotovo zbog radikalnog povećanja broja malignih bolesti. Pri tome se u potpunosti koriste službeni državni medicinski podaci koji se dovode u koleraciju s vojnim nuklearnim pokusima i izgradnjom nuklearnih centrala. Takva nova interpretacija stručnoj javnosti dostupnih javnozdravstvenih podataka prisutna je u radovima mnogih znanstvenika, a pogotovo treba ukazati na radove dr. Ernest J. Sternglassa, profesora emeritusa radiologijske fizike na Univerzitetu u Pittsburghu (koji je prošle godine posjetio Hrvatsku). Dr. Sternglass je desetljećima kao znanstvenik radio u nuklearnoj industriji, te je od samog početka njezina razvoja, govorio o velikim rizicima i iznimnoj štetnosti korištenja nuklearne tehnologije, kako u vojne tako i u civilne svrhe, te pogubnim kumulativnim utjecajima na zdravlje ljudi, okoliš i gospodarstvo u cjelini. Njegova je procjena da je niska radijacija iz nuklearnih centrala i od vojnih pokusa u pola stoljeća ubila preko 250 milijuna ljudi u svijetu. Cjeloviti intervju s dr. Sternglassom možete pronaći na:
http://www.slobodnadalmacija.hr/Hrvatska/tabid/66/articleType/ArticleView/articleId/111348/Default.aspx
Zaključno, nakon potresa u Japanu, nuklearne elektrane ponovo se pokazuju u svome punom sjaju, odnosno ukazuju na svoje pravo lice koje je inače prikriveno veoma skupom dimnom zavjesom enormnih količina laži i obmana kojima nas sustavno zasipa nuklearna industrija. Nuklearna industrija prepuna je dobro plaćenih eksperata koji će sada "stručno" objašnjavati zašto se dogodilo ono za što su nas do nedavno uvjeravali da predstavlja gotovo nemogući događaj. A potres je tek jedna u nizu potencijalnih opasnosti za nuklearke na koje mnogi ZAISTA nezavisni stručnjaci upozoravaju od samih početaka njihovog korištenja.
U Njivicama, 17. ožujka 2011. Za udrugu «Eko Kvarner»:
Vjeran Piršić, predsjednik
Postovi: 3594
PostPostano: 19.3.2011. sub. 15:25    Naslov: Citirajte i odgovorite
EV je napisao/la:
Ja eko udruzi Eko Kvarner i Vjeranu Prišiču i njegovim članovima poručujem da prvo sebe srede pa da tek tada protestiraju i baljezgaju gluposti.Moraju prvo napravit sljedeče
1/Iskopčat se sa Hepove mreže i preči u off grid opskrbe energije i na poslu i kod kuče.
2/Grijanje vlastitih domova samo pasivno ili obnovljivi izvori
3/Prestati se voziti u smrdljivim automobilima,avionima brodovima
4/ako se žele prebacivati iz mjesta u mjesto smiju koristit samo sljedeče.Električna vozila,životinjske zaprege i jedrilice i normalno pješke.
Kad to naprave neka se tada jave
Postovi: 12731
PostPostano: 19.3.2011. sub. 15:31    Naslov: Citirajte i odgovorite
Mi kao pojedinci ne možemo napraviti puno ali svi zajedno možemo sve
Ljudi su dio prirode
Zimi ima znatno manje sunčeve energije, priroda odmara, taj odmor je potreban i nama
Jednako kao i noć koju smo potisnuli umjetnom rasvjetom
Ne želim reći da bi trebali prespavati zimski san nego uskladiti aktivnosti sa raspoloživom energijom iz obnovljivih izvora
Postovi: 3594
PostPostano: 19.3.2011. sub. 20:35    Naslov: Citirajte i odgovorite
EV je napisao/la:
Ev ako i sami uštedimo 1 mw energije puno smo učinili na duge staze
I najduže putovanje uvijek počinje prvim korakom
Postovi: 12731
PostPostano: 19.3.2011. sub. 20:47    Naslov: Citirajte i odgovorite
Vjeran daje puno više sebe od prosjeka
Sudjeluje i u konkretnim projektima: http://www.ekokvarner.hr/content/view/60/66/lang,hr/
m2
Pridružen/a: 11. 06. 2008.
Postovi: 1374
PostPostano: 19.3.2011. sub. 21:18    Naslov: Citirajte i odgovorite
EV je napisao/la:
Upita perzijski "general" Xerxes Ephialtes-a kakvi su ratnici spartanci?
Ephialtes: Ništa bolji od bilo kojeg ratnika u pojedinačnoj borbi ali kada stanu jedan do drugoga.....
Rezultat: 300 spartanaca "za" 20,000 perzijanaca
Prošavši Thermopylae preko 300 spartanaca, na "drugoj strani" ga je čekalo 10,000 Spartanaca i 30,000 Grka, Xerxes se je zaključio da bez obzira što ima 3 puta veću vojsku ipak bi mu bilo pametnije da ode kući....
Postovi: 12731
PostPostano: 24.3.2011. čet. 21:43    Naslov: Citirajte i odgovorite
still nuclear power, but the reactor is 93 million miles away
Germany’s solar panels produce more power than Japan’s entire Fukushima complex
http://www.grist.org/article/2011-03-22-germanys-solar-panels-produce-more-power-than-japans-entire-fuku
PostPostano: 24.3.2011. čet. 22:39    Naslov: Citirajte i odgovorite
...ima toga još : Solar power plants in the Mojave Desert
http://en.wikipedia.org/wiki/Solar_power_plants_in_the_Mojave_Desert
Postovi: 2179
PostPostano: 25.3.2011. pet. 10:12    Naslov: Citirajte i odgovorite
Evo da malo pratimo stanje kod nas: http://www.dzns.hr/aktivnosti/pripravnost/pravodobno_upozoravanje
Kažu da je malo napuknuo reaktor br 3. i da nešto pušta.. Wink
Stranica 1 / 4.
