SEGWAY
-> Ostala e-vozila
Postovi: 12305
PostPostano: 10.8.2007. pet. 23:01    Naslov: Citirajte i odgovorite
Best described as a no-hands version of the Segway Personal Transporter, the Handsfree-Transporter developed by Ulrich Kahlert provides mobility at speeds up to 21km/h without whilst freeing up the hands for other tasks. Originally developed for theatrical purposes the device is ideal for a range of uses, particularly as a movable platform for Steadicam operators as well as to facilitate employee movement in various industries.
The Handsfree-Transporter is capable of travelling at a speed up to 21km/h for a distance of approximately 15km. It has a load capacity of 105kg, takes 5 hours to charge and weighs approximately 48kg. An Off Road version is also available further enhancing its usefulness as a camera platform.
MalaZelena
Pridružen/a: 13. 04. 2007.
Postovi: 631
PostPostano: 15.8.2007. sri. 10:10    Naslov: Citirajte i odgovorite
Zamišljam kako bi izgledalo raspasti se sa ovog seg-handsfree-a pri 20 km/h Very Happy
Zapravo, ne vidim ni neku posebnu praktičnu potrebu zašto bi trebao imati slobodne ruke dok se voziš na tome huh
Postovi: 12305
PostPostano: 30.7.2008. sri. 01:25    Naslov: Citirajte i odgovorite
Postovi: 12305
PostPostano: 1.11.2008. sub. 20:55    Naslov: Citirajte i odgovorite
Postovi: 2035
PostPostano: 1.11.2008. sub. 22:18    Naslov: Citirajte i odgovorite
MalaZelena je napisao/la:
http://www.youtube.com/watch?v=paV5jEnR2Oo&feature=related
otprilike ovako Confused
http://www.youtube.com/watch?v=ZaK8Pfhefl0 Rolling Eyes
Postovi: 12305
PostPostano: 2.11.2008. ned. 09:05    Naslov: Citirajte i odgovorite
aaaa..kako ju je zakucalo u pod Shocked
Postovi: 2035
PostPostano: 2.11.2008. ned. 14:54    Naslov: Citirajte i odgovorite
EV je napisao/la:
Točno to...i zato bih ja popravio tu njihovu konstrukciju s još jednim centralnim kotačem sa amortizerom i kočnicom koji bi bio na onoj šipki za koju se uhvatiš.... Wink ili čak dva kotača zbog stabilnosti... palac nek je i otpor veći ali da je sigurnost na prvom mjestu...
u biti sve su funkcije očuvane samo je ovo dodatno osiguranje i mogučnost relativno brzog kočenja ako se ne stigneš brzo nagnuti nazad...a ako padaš nazad uvijek možeš skočiti sa platforme...barem mi se tako čini
Postovi: 4341
PostPostano: 2.11.2008. ned. 16:04    Naslov: Citirajte i odgovorite
Daddy, kljucni dio sageway-a je gyroscope (bilo mi je lakse napisati na engl.).
Nisu potrebni nikakvi dodatni kotaci za suport as gyro drzi ravnotezu.
Nesto me vuce da napravim jedan s malo vecim kotacima, tj. s 26" i dva V4 motora. Rolling Eyes
Nazalost, gyro koji bihj volio koristiti za takav projekt je DS5000, koji kosta ist toliko, tj. 5000$, doduse, jest da je fiberoptic, ali cijena... Rolling Eyes
Postovi: 2035
PostPostano: 2.11.2008. ned. 20:12    Naslov: Citirajte i odgovorite
Da, da kužim ja žiroskope ali vidiš i sam da se možeš razbiti ako si malo živahniji s tim prometalom. Ja bih svakako volio da imam taj neki klasični mehanički kotač pa makar bilo sve to ružnjikavo i nezgrapno jer volim malo živahnije vožnje... Very Happy ..sjećaš se kako sam tresnuo tamo na parkingu s bikeom... smijeh2
E a ova tvoja ideja bi bila sasvim ok ali bih ja od toga napravio romobil...i to 2WD... smijeh1
http://www.youtube.com/watch?v=BPpjb_uZr6Y
Postovi: 5033
PostPostano: 3.11.2008. pon. 00:31    Naslov: Citirajte i odgovorite
ako odlucis raditi tak nekaj javi da ti nabavim povoljniji gyro (imas u svom helicu jedan nadam se)...
z
Postovi: 4341
PostPostano: 3.11.2008. pon. 01:38    Naslov: Citirajte i odgovorite
Bila je rijec o fiberoptickom gyro-u. Prednost je bila da gyro ima direktno RS232 izlaz (38400bps), a salje van prema izboru rotacionu brzinu ili integrirani kut. Smile
Kad sam sastavljao uredjaj, kopao sam po internetu za fiberopticke gyro-e i za sada najjeftinije sam nasao kod Fizioptike (firma u Rusiji, predstavnistvo u Svicarskoj), ali nije lako se spojiti na isti as ima samo analogni izlaz pa treba 24bit D/A.
Ako imas ca zgodnog, posalji mi na email da vidim, na proljece ce mi trebati vjerojatno tri komada, vjerujem da cu tada poceti raditi projekt za prvi DP class brod u Hrvatskoj. Very Happy
Postovi: 5033
PostPostano: 3.11.2008. pon. 11:21    Naslov: Citirajte i odgovorite
Ima ih za 50-100$ 3 osni gyro sa PWM izlazom, digitalnim izlazom, potovima za trimanje offseta ako valjaju za helikopter onda bi valjda bili dobri i za ovo cudo (nemoj odustat zbog gyroa)...
Uglavnom do 500$ nadjes gyro kakav oces ziher!
Oldi, imas kaj za dodat??
Postovi: 4341
PostPostano: 3.11.2008. pon. 14:11    Naslov: Citirajte i odgovorite
dOdal sam ti na email: potrazi mi malo pa mi mailaj, svakako da sam zainteresiran...
Cak i troosni, ako uspijem dovoljno kvalitetan naci, uzeo bih sigurno barem jedan.
Zadnje sto sam gledao od fiberoptickih gyro-a prije tri godine, bili su skupi k'o papar.
m2
Pridružen/a: 11. 06. 2008.
Postovi: 1343
PostPostano: 7.4.2009. uto. 21:22    Naslov: Citirajte i odgovorite
segwayPuma opet nešto izmišljaju, neznam dali plakati ili se smijati tko se uopče želi voziti u nečemu što izgleda kao invalidska kolica (osim nažalost ako nema drugog izbora)
http://www.treehugger.com/files/2009/04/segway-puma-would-you-drive-it-in-traffic.php smijeh1 placko
elektro
Pridružen/a: 16. 08. 2008.
Postovi: 163
Lokacija: Frankfurt / Njemacka
PostPostano: 8.5.2009. pet. 13:00    Naslov: Citirajte i odgovorite
konkurencija za Segway - a od Toyote ?
http://blading.at.webry.info/200808/article_4.html
http://www.toyota.co.jp/en/tech/p_mobility/i-real/index.html
-> Ostala e-vozila
Stranica 4 / 6.
