Proizvodnja el. struje i tople vode solarnim koncentratorima
-> Solarni kolektori
m2
Pridružen/a: 11. 06. 2008.
Postovi: 1339
PostPostano: 1.6.2009. pon. 14:25    Naslov: Proizvodnja el. struje i tople vode solarnim koncentratorima Citirajte i odgovorite
Proizvodnja el. struje i tople vode solarnim koncentratorima korištenjem auto djelova. The ORC engine is constructed using standard automotive parts (power steering pump, alternator, bearings, pulleys and motors) that are high volume, low cost and ubiquitous.
http://stginternational.org/how-it-works.html
http://www.nciia.org/WebObjects/NciiaResources.woa/wa/View/GrantProfile?n=1000574
Unlike standard photovoltaic panels, which only produce electricity, the team’s device meets the entire range of commercial and residential energy needs: heating, cooling, and electricity.
Interesantno za samogradnju!!!
Thermal Input
* Direct Sunlight
o 800-1000 W/m2, peak
o 400-600 W/m2, nominal
* 50-70% thermal collector efficiency
Collector Thermal Output
* 650 W/m2 peak thermal output
* 150º C max. temperature
* 70 m2 array = 40 kW thermal, nominal
ORC Heat and Power Outputs
* 3 kW electrical / 23 kW thermal (co-generation mode)
o up to 15% thermal-electric efficiency
o 2-10% solar-electric efficiency
* 48V DC output (battery charging)
* 220 V AC inverter
* 1000 L hot water / day
m2
Postovi: 1339
PostPostano: 12.6.2009. pet. 00:59    Naslov: Citirajte i odgovorite
Solarni toranj sa mikro turbinom, preko dana na solar, preko noći na neki drugi energent (bio plin npr.)
http://www.aora-solar.com/
m2
Postovi: 1339
PostPostano: 11.8.2009. uto. 14:39    Naslov: Citirajte i odgovorite
Još jedan "toranj"
http://www.esolar.com/solution.html
"I´d put money on the sun & solar energy. What a source of power! I hope we don´t have to wait until oil and coal run out before we tackle that. I wish I had more years left." Thomas Edison, 1931
SK sun
Pridružen/a: 08. 10. 2009.
Postovi: 11
PostPostano: 13.10.2009. uto. 16:00    Naslov: Citirajte i odgovorite
Molio bih te ako možeš da promijeniš sliku avatara jer se ne mogu koncentrirat na ono što pišeš!
PostPostano: 13.10.2009. uto. 16:50    Naslov: Citirajte i odgovorite
SK sun je napisao/la:
smijeh2 palac
m2
Postovi: 1339
PostPostano: 14.10.2009. sri. 11:41    Naslov: Citirajte i odgovorite
Ok probati ću nači neku veču bubetinu
Postovi: 4312
PostPostano: 14.10.2009. sri. 14:48    Naslov: Citirajte i odgovorite
m2 je napisao/la:
Najbolje da bude zohar. Wink palac
pedjamil
Pridružen/a: 24. 01. 2008.
Postovi: 517
Lokacija: Beograd
PostPostano: 14.10.2009. sri. 17:29    Naslov: Citirajte i odgovorite
Tarantula ?
peco
Pridružen/a: 07. 05. 2009.
Postovi: 1175
Lokacija: Os.-Slavonija
PostPostano: 14.10.2009. sri. 19:06    Naslov: Citirajte i odgovorite
m2 je napisao/la:
to i je zohar, samo maleni
Postovi: 2453
PostPostano: 14.10.2009. sri. 22:50    Naslov: Citirajte i odgovorite
Sad sam vec navikao na takve avatare u pocetku sam uredno zveknuo po monitoru.
m2
Postovi: 1339
PostPostano: 15.10.2009. čet. 07:27    Naslov: Citirajte i odgovorite
creatin je napisao/la:
Ako si razbio monitor tražiti ču popust kod prodavača monitora jer im poboljšavam biznis smijeh1 smijeh2
Postovi: 2453
PostPostano: 15.10.2009. čet. 18:38    Naslov: Citirajte i odgovorite
Prvi crt sam posteno zaljuljao nakon pohoda na ekran Smile
PostPostano: 17.10.2009. sub. 17:04    Naslov: Citirajte i odgovorite
Ne znam jel ovo tu već bilo , ali ako nije - zanimljivo je .
http://www.hobiportal.com/dokument/samogradnja_kolektora.pdf
PostPostano: 21.10.2009. sri. 20:51    Naslov: Citirajte i odgovorite
Isplati li se ovo raditi ? Koliko bi ovo ( ako bi moglo Rolling Eyes ) ugrijalo vodu u 11. , 2., 3., mjesecu ?
SK sun
Postovi: 11
PostPostano: 22.10.2009. čet. 10:00    Naslov: Citirajte i odgovorite
E to bi trebalo vidjet sa momcima koji su to radili. Znam iz Zelene akcije da su radili momci, a ovdje s foruma nemam pojma. Po zimi ako ima sunca valjda se dobije oko 10-15 stupnjeva, što je opet bolje od 5 stupnjeva, jer onda ovu vodu dogrijavaš za grijanje. Isplativo u svakom slučaju kako god da okreneš. Pogotovo za ljeto i tuširanje. Da uštediš samo za tuširanje ljeti, već si puno dobio.
