HHO
Idite na Prethodna  1, 2, 3, ... 98, 99, 100  Sljedeća
-> Besplatna energija
ivans
Pridružen/a: 30. 03. 2008.
Postovi: 303
Lokacija: iza horizonta
PostPostano: 11.5.2009. pon. 11:01    Naslov: Citirajte i odgovorite
Dali bi neko preveo ovo na naski?
There are two primary frequencies that produce the best results. They are: 14,372 Hz and 43,430 Hz. The former is about 50% more efficient, but it seems that just about any frequency between 9 KHz and 143,762 KHz works quite well. (1) This is because the nature of the wave form ( a spike ) is rich in harmonics and one of them is bound to be close to one of the two primary frequencies.
Use of permanent magnets may also increase efficiency. I'll give you the outcome of that attempt in my next letter along with the plans for what I hope to be a much improved version.
Note: Sub-harmonics of the two primary frequencies at which dissociation will occur:
43430 Hz
SUBHARMONIC
1st 21715 HZ
2nd 14476.67 HZ
3rd 15517.5 HZ
4th 8686
143762 HZ
SUBHARMONIC
1st 71881 HZ
2nd 47920.67 HZ
3rd 35840.1 HZ
4th 28752.4 HZ
*1500 VOLTS IS THE MINIMUM REQUIRED FOR MOLECULAR RINGING TO BEGIN.
Zapravo, treba nam oscilator koji bi napravio ovo sto se trazi...
ubi me struja
Pridružen/a: 13. 10. 2008.
Postovi: 152
Lokacija: Sarajevo
PostPostano: 11.5.2009. pon. 12:02    Naslov: Citirajte i odgovorite
Ma meni je to sve UFO tehnologija, mislim, mogla bi se naći harmonika i ispod nje staviti još jednu kao subharoniku ali teško da će raditi na 1500V
smijeh2 smijeh2 smijeh2 smijeh2
ivans
Postovi: 303
PostPostano: 11.5.2009. pon. 13:18    Naslov: Citirajte i odgovorite
A negde ranije u tekstu je pisalo da radi na 24V Rolling Eyes
http://www.rexresearch.com/meyerhy/meyerhy.htm
nikola
Pridružen/a: 29. 12. 2008.
Postovi: 311
PostPostano: 11.5.2009. pon. 16:59    Naslov: Citirajte i odgovorite
Još par videa na koje sam naletio:
http://www.youtube.com/watch?v=igGCH8G3Mzk&feature=related
http://www.youtube.com/watch?v=3JbXLGIL_fc&NR=1
http://www.youtube.com/watch?v=YtKRe4bkBLI&NR=1
nikola
Postovi: 311
PostPostano: 12.5.2009. uto. 12:30    Naslov: Citirajte i odgovorite
Zanimljivo ...Cool
http://www.youtube.com/watch?v=11Qn4CGlZp4&feature=related
Kakva je ovo žica na kraju videa??
Nixa
Pridružen/a: 23. 04. 2007.
Postovi: 1107
Lokacija: Crazy Hill
PostPostano: 12.5.2009. uto. 13:11    Naslov: Citirajte i odgovorite
nikola je napisao/la:
Nehrđajuća sajla... Rolling Eyes
nikola
Postovi: 311
PostPostano: 12.5.2009. uto. 19:55    Naslov: Citirajte i odgovorite
Kaj bi to poboljšalo proizvodnju HHO?
Postovi: 4887
PostPostano: 12.5.2009. uto. 21:52    Naslov: Citirajte i odgovorite
ne nego bi produzilo trajnost celije...
grba
Pridružen/a: 01. 05. 2009.
Postovi: 171
PostPostano: 14.5.2009. čet. 06:33    Naslov: Citirajte i odgovorite
Evo, kao sto sam obecao... Kompletna uputstva za izgradnju celija sa videom
link:
http://rapidshare.com/files/232739610/Vodonik.rar
Nixa
Postovi: 1107
PostPostano: 14.5.2009. čet. 07:00    Naslov: Citirajte i odgovorite
Ja sam za probu napravio jednu malu čeliju od cca 3l.
Mogu reći da je ODLIČNO gutala ampere bez obzira na AC, DC, PWM...
Čak sam probal staviti destiliranu vodu i polako dodavati nećistoće da bi provodila struju, al bezuspješno...
Postovi: 4292
PostPostano: 14.5.2009. čet. 10:36    Naslov: Citirajte i odgovorite
Nixa je napisao/la:
Najjednostavniji generator: stari startni akumulator spojis na DC izvor te rijesis automatsko dolivanje vode i prepunjavas ga, tesko ce ga bilo koja druga konstrukcija HHO celije "potuci"... Cool
Problem je da ipak moras unijeti vise energije nego sto je mozes izvuci sagorijevanjem generiranog plina... Rolling Eyes
nikola
Postovi: 311
PostPostano: 14.5.2009. čet. 16:25    Naslov: Citirajte i odgovorite
Nixa je napisao/la:
Pa stavi sodu bikarbonu unutra ak očeš da bolje provodi te da manje struje guta. Rolling Eyes
Postovi: 1370
PostPostano: 14.5.2009. čet. 19:45    Naslov: Citirajte i odgovorite
Eto, ja nabavio 20 inox ploča 10x10 cm hehehe
ubi me struja
Postovi: 152
Lokacija: Sarajevo
PostPostano: 14.5.2009. čet. 20:18    Naslov: Citirajte i odgovorite
Potpisujem ovo gore što Pero napisa!
Ništa se nemože mjerit sa običnim akumulatorom, nikakve ploče, cjevi, žice i pletenice.
npr. akumulator 61Ah 12V doslovno u 10 sec. "ispari" svih 1,5 lit. vode koliko u njega stane "voltažu" možete birati proizvoljno, bitno je da mu dovedete 50 ili više A (što više A to brže do HHO Cool ) uz sve to netreba nikakva kemija za dodavat, samo obićna voda!
Ipak ja sam se zbog viših napona odlučio na kobinaciju gusa i bakra, e to će te uskoro i vidjeti i čuti; više od 50 lit/min (ganjam sad 70/80 litara po minutu jer hoću sa time upaliti motor auta!)
grizli
Pridružen/a: 14. 05. 2009.
Postovi: 80
PostPostano: 14.5.2009. čet. 21:46    Naslov: Citirajte i odgovorite
ubi me struja je napisao/la:
Ako ti elektrolizer trosi 7kW i daje SAMO 18kW toplinske energije(gorenje vodika) kako mislis upakiti auto? ako je iskoristivost auta 30%, recimo da je zbog nize temerature rada na vodik i 50% to znaci da bi ti za 80kW auto npr trebalo 160kW toplinske energije vodika.
Kako to da koristis bakat , kako uopce mozes koristiti bakarnene ploce a ne iskljucivo inox? pa zar se bakar ne disocira u otponi Koh ?
Te pretpostavljam da si napravio serijski elektrolizer , mozes li poslat koju sliku ? tj kako si napravio kucite u koje si utaknuo ploce od metala ? jer platicno s urezima ili hmm ?
kako mislis dobit 70 lit po minuti ? pa zar nebi za to trebao po sadasnjoj efikasnosti jedno 15kW struje?
Znam neke ljude koji tvrde da se gorenjem vodika oslobađa zabravo mnogo vise topline ?! a ti dobih samo 18kW...
ako je tako jedini nacin da vozis auto je da na auto od 100kW bude zakacen alternator od 50kW Very Happy npr..
ili mozda napravit elektricni auto u kojem je recim 30kW generator na vodik koji radi konstantno i puni baterije.
ali to je sve na knap ... hmm
O vodiku ima vise prica nego o drugu Titu i partizanima hehe Very Happy
Morat cu ja uskoro napravit manji elektrolizer zapalit hho i izmjerit kaloricnost plina tj gorenja.. samo je pitanje kako najefikasnije ?! any idea ?
Stranica 2 / 100.
