Električni avioni
Idite na Prethodna  1, 2, 3, 4, 5
-> Električne letjelice
Postovi: 12195
PostPostano: 21.4.2017. pet. 20:14    Naslov: Citirajte i odgovorite
Ovako mala krila ne čine neku razliku pri manjim brzinama u odnosu na ove bez krila: http://www.e-vozila.com/forum/viewtopic.php?p=148987#148987
..ali pri većim brzinama vjerojatno troši puno manje.
Zanimljivo! Smile
Postovi: 1071
PostPostano: 26.4.2017. sri. 10:30    Naslov: Citirajte i odgovorite
Ispravak
Zadnja promjena: rkahler; 16.5.2019. čet. 11:04; ukupno mijenjano 1 put.
Pridružen/a: 01. 01. 2012.
Postovi: 1031
PostPostano: 1.12.2017. pet. 06:52    Naslov: Citirajte i odgovorite
Neznam dali je netko ovo bio stavio, ali meni izgleda jako impresivno. https://m.youtube.com/watch?v=eNSN6qet1kE
Postovi: 2037
PostPostano: 1.12.2017. pet. 09:22    Naslov: Citirajte i odgovorite
miko je napisao/la:
stvarno impresivno, jest da je na nivou braće "Rajt" ali sa aspekta pojedinca - impresivno i danas
m2
Pridružen/a: 11. 06. 2008.
Postovi: 1329
PostPostano: 10.4.2018. uto. 14:10    Naslov: Citirajte i odgovorite
Norway plans to boost electric airplane development
https://avinor.no/contentassets/c29b7a7ec1164e5d8f7500f8fef810cc/introduction-of-electric-aircraft-in-norway.pdf
Postovi: 2037
PostPostano: 27.8.2018. pon. 09:20    Naslov: Citirajte i odgovorite
https://www.youtube.com/watch?v=VhEiM2VoEPg&feature=youtu.be
Zašto sam stavio ovaj link? Zbog jednog komentara na koji način čovjek koristi avion za izbjegavanje gužvi u saobraćaju Very Happy
Citat:
The owner of this particular aircraft has a practical mission for this plane. It is to avoid traffic when commuting within the lower mainland in and around the Vancouver area.
I believe this aircraft to be a near perfect fit for his mission.
Since the aircraft is the first of it's kind, there are no other charging stations in place at airports other than the one in his hangar (at the time of replying to this comment Feb 2018), or the one he is planning to place at his destination airport. This will change gradually.
Incidentally, the day I travelled to this location in my automotive fuel powered Pipistrel Virus SW to fly in the Alpha Electro, AVGAS was quarantined across Canada due to quality control issues.
Postovi: 4277
PostPostano: 27.8.2018. pon. 12:42    Naslov: Citirajte i odgovorite
BB je napisao/la:
Za�to sam stavio ovaj link? Zbog jednog komentara na koji na�in �ovjek koristi avion za izbjegavanje gu�vi u saobra�aju Very Happy
Super fora - vidim da spominju potrosnju (po predjenom putu) usporedivu sa Teslom:
https://insideevs.com/first-electric-aircraft-to-enter-serial-production-takes-flight-buy-yours-now/
(potrazi "Model S" na stranici)
fire
Pridružen/a: 16. 02. 2009.
Postovi: 803
PostPostano: 27.8.2018. pon. 13:15    Naslov: Citirajte i odgovorite
BB je napisao/la:
Dok stave 900kWh baterije u avion, nece bas vise biti lagan. Ni priblozno kao ovaj model od 350kg.
Postovi: 2037
PostPostano: 28.8.2018. uto. 09:52    Naslov: Citirajte i odgovorite
fire je napisao/la:
BB je napisao/la:
Ne treba stvari vulgarizovati...
Avion je možda najbolji primjer kao zbir kompromisa. Ni jedan nije idealan, već samo dovoljno dobar za određenu misiju. Ovaj vlasnik je uklopio električni avion u svoju misiju.
Podatak za 900kWh se odnosi na link koji vodi na potpuno drugi avion, koji je dijametralno različit po performansama i nosivosti https://insideevs.com/this-electric-aircraft-features-a-900-kwh-battery-650-mile-range/
Mada i tu baterije dolaze do težine 3461kg (po gore navedenim specifikacijama) što je puno i za avion od 9 mjesta
Raravno pipistrel alpha je realan avion koji se može kupiti dok Eviation je tek na "papiru" (čitaj mamac za investitore).
Postovi: 1071
PostPostano: 6.11.2018. uto. 12:41    Naslov: Citirajte i odgovorite
https://www.bug.hr/transport/easyjet-se-nada-prometovati-elektricnim-zrakoplovima-od-2030-godine-6576
Postovi: 661
PostPostano: 13.11.2018. uto. 09:12    Naslov: Citirajte i odgovorite
https://novac.jutarnji.hr/novi-svijet/izraelci-najavili-prvi-elektricni-komercijalni-avion-prima-9-putnika-i-prelazi-1000-km/8049014/
https://youtu.be/1OIDWwV_kRE
BuBi_zgb
Pridružen/a: 25. 01. 2011.
Postovi: 596
PostPostano: 22.11.2018. čet. 08:37    Naslov: Citirajte i odgovorite
https://www.popsci.com/ion-drive-airplane
https://www.engadget.com/2018/11/21/mit-ionic-wind-aircraft-flies/?sr_source=Facebook
Postovi: 1071
PostPostano: 16.5.2019. čet. 11:06    Naslov: Citirajte i odgovorite
Lilium
https://www.telegram.hr/biznis-tech/njemacki-startup-koji-tvrdi-da-ce-imati-letece-taksije-do-2025-godine-upravo-je-uspjesno-odradio-vazan-testni-let/
Postovi: 12195
PostPostano: 16.5.2019. čet. 14:06    Naslov: Citirajte i odgovorite
Citat:
Iz Liliuma tvrde da je efikasnost njihovog peterosjeda usporediva s električnim automobilom na istoj udaljenosti.
Shocked
Pridružen/a: 15. 10. 2014.
Postovi: 990
PostPostano: 16.5.2019. čet. 16:58    Naslov: Citirajte i odgovorite
je,sam kaj se trese kao suhi list
Stranica 5 / 5.
