Buggy Carter GTR Interceptor
Idite na Prethodna  1, 2, 3, 4, 5, 6, 7, 8, 9  Sljedeća
-> Samogradnja ostalih e-vozila
Caca
Pridružen/a: 08. 09. 2008.
Postovi: 699
Lokacija: Karlovac
PostPostano: 1.10.2018. pon. 10:32    Naslov: Citirajte i odgovorite
dmeter je napisao/la:
Je li moze ovaj BMS radit samo u 4S kombinaciji.
Bi li mogao probati sa 4S i javit mi da ga ne kupujem bezveze.
to je ovaj je li tako. https://www.aliexpress.com/store/product/150A-8S-24S-Lithium-Battery-Protection-Board-Smart-Display-Balance-BMS-Coulomb-Meter-Ternary-lifepo4-iron/2856009_32849338845.html?spm=2114.12010612.8148356.14.6f9a3de2IJRlUq
Minimalno je 8s, gore je DC-DC step down koji napaja elektroniku, BT adapter pa vjerujem da mu je nekih 20V minimum... Nisam probao uglavnom, ovo je po papirima 8S
Caca
Postovi: 699
Lokacija: Karlovac
PostPostano: 11.10.2018. čet. 19:31    Naslov: Citirajte i odgovorite
Nakon mjesec dana napokon stigao motorić! Motenergy ME1306.
Output Power of 10 KW Continuous, 30 KW Peak.
3-phase, Y-connected Permanent Magnet Synchronus Motor with an axial air gap.
The motor is 92% efficient at voltages between 24 to 96 VDC.
This is a 4 pole motor (8 magnets).
The Phase to Phase winding resistance is 0.013 Ohms.
The maximum recommended rotor speed is 5000 RPM.
Voltages from 0 to 96 VDC input to the control.
Torque constant of 0.15 Nm per Amp.
The Inductance Phase to Phase is 0.20 Milli-Henry.
Armature Inertia is 45 Kg Cm Squared.
Continuous current of 125 Amps AC (180 Amps DC into the motor control).
Peak current of 420 Amps AC for 1 minute (600 Amps DC into the motor control).
Weight of 36 pounds (16.3 kg).
Peak Stall Torque is 90 Nm.
This is an Open Frame, Fan Cooled motor.
Temperature sensor KTY84-130
U/V/W encoder
Sad za vikend moram još sve izmjeriti, nacrtati ploču za njega i dati izrezat pa sve lijepo dat povarit. Preko zime ću se igratI sa podešavanjem kontrolera jer tu će bit dosta posla tako da u proljeće imam sve spremno za montiranje postovanje1
Postovi: 12168
PostPostano: 11.10.2018. čet. 21:03    Naslov: Citirajte i odgovorite
Lijepo, uživaj! palac
Caca
Postovi: 699
Lokacija: Karlovac
PostPostano: 11.10.2018. čet. 21:10    Naslov: Citirajte i odgovorite
ogi je napisao/la:
Ogi uživam ja već godinu dana al ja bi se vozio! smijeh1
Postovi: 636
PostPostano: 12.10.2018. pet. 06:45    Naslov: Citirajte i odgovorite
palac Super!
Gdje si kupio i koliko si platio? Dostava? Carina? PDV?
Caca
Postovi: 699
Lokacija: Karlovac
PostPostano: 12.10.2018. pet. 09:19    Naslov: Citirajte i odgovorite
OldDog je napisao/la:
palac Super!
Motorić je kupljen u EU, Francuska, dostava gratis!
http://kartmasters.fr/shop/en/synchronous-motors/1971-me1306-pmsm-brushless-motor.html?search_query=1306&results=13
Postovi: 1994
PostPostano: 12.10.2018. pet. 15:12    Naslov: Citirajte i odgovorite
Caca je napisao/la:
palac Super!
bi li to moglo bubu tjerati?
Caca
Postovi: 699
Lokacija: Karlovac
PostPostano: 12.10.2018. pet. 18:39    Naslov: Citirajte i odgovorite
BB je napisao/la:
Caca je napisao/la:
palac Super!
Pa ja vjerujem da ne bi bio problem ali za bubu rađe pogledaj ME1304 sa vodenim hlađenjem, nekih 14,5kW konstantno. http://kartmasters.fr/shop/en/synchronous-motors/674-me1304-pmsm-brushless-motor.html?search_query=1304&results=12
Postovi: 864
PostPostano: 13.10.2018. sub. 11:58    Naslov: Citirajte i odgovorite
Štima palac
Postovi: 4793
PostPostano: 13.10.2018. sub. 13:05    Naslov: Citirajte i odgovorite
BB je napisao/la:
Caca je napisao/la:
palac Super!
Ni blizu.
Postovi: 2302
PostPostano: 14.10.2018. ned. 06:03    Naslov: Citirajte i odgovorite
BB je napisao/la:
Caca je napisao/la:
palac Super!
Ni blizu.
Zašto ? ako može original benzinac 18kW il puno slabijii DC Končar 5kW spram ME1306 PMSM Output Power of 10 kW Continuous, 30 kW Peak.
Postovi: 4278
PostPostano: 14.10.2018. ned. 06:42    Naslov: Citirajte i odgovorite
Ispada da može dati kontinuirano 11kW snage pri 6000RPM (samo 20% iznad preporučenog max. RPM), a u peaku može dati preko 3.5 puta više kroz jednu minutu.
Ne vidim koji je promjer osovine motora, da se dade provjeriti izdržljivost istog na peak momente. Predpostavljam da s ograničenjem fazne struje na 420A neće doći do preopterećenja osovine, tj. do loma iste...
Sasvim dovoljno za nekoga ko nema pretjerane zahtjeve...
Ne mora uvijek biti trkaći auto, za grad max brzina od 70km/h je više nego dovoljna, ionako rijetko gdje ćeš prijeći i 40km/h.
Nije za veće udaljenosti, niti za autocestu, ali to je sasvim zgodan motorić za manje el. vozilo i za gradsku vožnju...
Ostavimo Rimcu da radi trkaće aute, a ovo je sasvim solidan motorić za pregradnju, iako bih ga radije ugradija u manje vozilo od bube...
Caca
Postovi: 699
Lokacija: Karlovac
PostPostano: 14.10.2018. ned. 08:17    Naslov: Citirajte i odgovorite
Osovina je 7/8" a njegov prethodnik, ME0913 se nalazi u nekim preradama tako da ne vidim razlog zašto ne bi mogao u manji autić pa i bubu.
Caca
Postovi: 699
Lokacija: Karlovac
PostPostano: 14.10.2018. ned. 09:01    Naslov: Citirajte i odgovorite
Evo ovako sam si to nekako zamislio.
Izmjerio sve, nacrtao novi nosač i on bi trebao ovako izgledati
Nedostaje još utor za disk i naravno rupe za vijke
Zadnja promjena: Caca; 14.10.2018. ned. 09:34; ukupno mijenjano 1 put.
Postovi: 4793
PostPostano: 14.10.2018. ned. 09:14    Naslov: Citirajte i odgovorite
max je napisao/la:
BB je napisao/la:
Caca je napisao/la:
palac Super!
Ni blizu.
Nema šanse, biti će jedva i za ovaj buggy. Uglavnom nisu svi kW isti.
Stranica 7 / 9.
